Resource icon
Modifying Apple's CD extension for use with 3rd Party Drives
If you ever had issues trying to get a 3rd Party CD drive to work in your Mac - this will be some required reading.
Thanks to Anthony Saxton, the author of ClipDragon, it's now posible to have a single modified driver work with both Apple CD drives, and any other SCSI CD ROM drive.
The screeshots below are for the Apple CD/DVD Driver 1.0.1. with additional descriptions for:
  • Apple CD-ROM 5.4.2​
  • Apple CD/DVD Driver 1.2​
  • Apple CD/DVD Driver 1.2.2​
  • Apple CD/DVD Driver 1.3.1​
  • Apple CD/DVD Driver 1.3.5 (no change since 1.3.1)​
  • Apple CD/DVD Driver 1.4/1.4.3 (no change since 1.3.1)​
Open a copy of the CD Driver in ResEdit and find the DRVR resources.
Open them with a double-click.
Open ID# 32 with a double-click.
If you get an error about the resource size, open it using the menu item "Open using Hex Editor"
The screenshot above for the Apple CD/DVD Driver 1.0.1 is representative of the changes to be made in all the drivers.
Find the original value at the appropriate row and offset, and change it to the new value.
Below is a table for first change in the various AppleCD drivers.
Version​
Row​
Offset​
Original Value​
New Value​
5.4.2​
06B0​
06B6​
6704​
4E71​
1.0.1​
06C8​
06C8​
6704​
4E71​
1.2​
06C0​
06C6​
6706​
4E71​
1.2.2​
06D8​
06D8​
6706​
4E71​
1.3.1​
06D0​
06D6​
6706​
4E71​
The graphic above, and the table below show the second change to be made to the driver.
Version​
Row​
Offset​
Original Value​
New Value​
5.4.2​
09C0​
09C6​
6606 4A84 6700 0086​
4E71 4E71 4E71 4E71​
1.0.1​
0A10​
0A10​
1.2​
0AD0​
0AD6​
6604 4A84 6706​
4E71 4E71 4E71​
1.2.2​
0AE8​
0AE8​
6604 4A84 6706​
4E71 4E71 4E71​
1.3.1​
0AE0​
0AE6​
6604 4A84 6706​
4E71 4E71 4E71​
When you're finished, replace the original driver with the new one and restart your computer. Your Apple supplied CD ROM driver will now mount most SCSI CD ROM Drives!
Unfortunately, the edit doesn't work with every combination of CD drive and computer, but 90% should.
Reactions: The House of Moth
Kai Robinson
1,771
0.00 star(s) 0 ratings
More resources from Kai Robinson
