[eMac/1.25] OS 9 no longer boots after installing OS X on separate partition
Hâlian
10
Hokay so. I wiped my 1.25 GHz eMac's drive and added an OS 9 partition from within the Mac OS 9 Lives' unsupported G4s ISO of OS 9, to which partition I installed OS 9 using the same ISO. I later added Tiger and Leopard partitions from within Fienix Linux, then used the standard Tiger DVD to install Tiger. Now that I've installed Tiger, however, OS 9 no longer shows up in the boot picker, and I can't boot using
Code:
boot hd:,\\:tbxi
in Open Firmware, even though the OS 9 System Folder shows as blessed in OS X (that is, has the orange 9 on its icon). What can I do to fix this, ideally without having to reïnstall OS 9?
