ADB -> USB Keyboard+Mouse Adapter Firmware
This resource is dedicated to the testing and conversion of ADB devices to USB for use on modern computers, emulators or authentic-esque hackintosh etc.
This example will be using an ATmega32u4 5v 16 MHz Pro Micro controller with micro USB port.
An example can be purchased here: ATMega32U4 Pro Micro
My build environment is Windows based but MacOS/Linux equivalents of the following software is available.
The first program required is AVRDude, a utility to upload our firmware to Pro Micro.
AVRDude download: Release Page
Depending on libraries already installed to your OS you may require WinAVR which includes necessary Arduino library .dll files OR AVRDude may complain of missing "Libusb0.dll".
WinAVR download: WinAVR
Lastly the firmware to interpret ADB protocol is attached to this article, click the "Download" button at the top of the page.
Extract AVRDude to a folder on your HDD and place the "ADB.Hex" file in the root directory.
example: C:\ADB.Hex
Required components: ATMega32u4, mini 4pin din (male or female), 1k - 10k Ohm Resistor, 3 wires.
You will want to know exactly what Com port the Pro Micro is assigned, Open up device manager and plug in the device. Here we see it appears as "USB Serial Device (Com 5)"
Open your Command Prompt as Administrator and navigate to your C:\
knowing YOUR com port prep the following command BUT Don't execute just yet!
avr\avrdude -p ATmega32u4 -P COM5 -c avr109 -U flash:w:ADB.hex
The Pro Micro will need to be tripped into boot mode to accept our firmware, this is achieved by bridging GND + RST twice, slowly. Once you've done that hit "Enter" and execute the command.
If successful AVRDude will begin the erase and flash process on the Pro Micro, It should look like the following:
If flash verified, you are now ready to assemble the device!
The ADB connection is quite simple and only requires 3 wires and one pull up resistor. You can see the pinout here:
It's important to note that the device should ALWAYS be inserted into the ADB port first! "hotplugging" not suggested. After Windows detects the adapter you can use any given program to test the keyboard and mouse, here I am using "AquaKey" a lightweight keyboard test utility. While my DataDesk Trackboard has a built in mouse you can use any ADB mouse on the opposite port of the keyboard.
You can dress up your new adapter any way you like, I currently have no appropriate housings or shrink tubing so kepton tape may have to do!
Have any additions, Suggestions or Inquiries? Let us know!
:D Congratulations on getting this far!
Drake
Downloads
2,996
7,299
4.50 star(s) 2 ratings
Latest reviews
Hi. I am using real Apple ADB Keyboards with recent Apple Macs. I believe Option-Control-Command are swapped somehow. Is there a way to fix that in the firmware? Binary edit is fine to me.
for Mac OS users with brew, you can run "brew install avrdude".
To find your ports you can run "ls /dev/{tty,cu}.*", which will list something like "/dev/tty.usbmodem31101"
Your terminal command would look something like:
avrdude -p ATmega32u4 -P /dev/cu.usbmodem31101 -c avr109 -U flash:w:adb.hex
Drake
Drake
Thanks for adding this!
