Identifying Motorola 68000 series CPUs
First Position - Status
MC​
  • Fully certified and vetted
XC​
  • Engineering sample
  • Pilot production
  • It may have bugs, according to some reports, that the software emulation for floating point in the 680LC40 does not work properly under XC status.
Second Position - Type of CPU
68​
  • Entire core of features
  • Memory Management Unit (MMU)
  • Floating Point Unit (FPU)
68EC​
  • Primarily for embedded systems
  • Excluding MMU and FPU
  • MMU replaced by two access control units (ADU)
68LC​
  • MMU
  • No FPU
  • It could run floating point instructions via software emulation, but slower than the 68040 and depends on the app.
Third Position - Model
000 - 68000​
020 - 68020​
030 - 68030​
040 - 68040​
060 - 68060​
Fourth Position - Form Factor
RC - Ceramic PGA (Au/Pb finish)​
RP - Plastic PGA​
FE - Quad Flat Package​
FG - Thin Quad Flat Package​
Fifth Position - Clock Frequency
16 - 16MHz​
25 - 25MHz​
33 - 33MHz​
and so on...​
Sixth Position - Revision
B - First revision​
C - Second revision​
D - Third revision (?)​
E - Fourth revision (?)​
V - I need to study that to make sure I can explain that one better for the next version of this guide. :)​
Version 1.3
#MARCHintosh 2023
1680058132608.png​
retr01
4,350
5.00 star(s) 1 ratings
More resources from retr01
Latest reviews
Great research!
