Resource icon
Managing Type and Creator Codes from macOS/MacOS X
Here is an applescript you can compile to an application for drag and drop purposes to set Creator and Type codes. You can modify it to suit your needs.
-t is for TYPE and -c is for CREATOR
on open filelist
repeat with i in filelist
do shell script "SetFile -t 'TEXT' -c 'R*ch' " & quoted form of POSIX path of i
end repeat
end
open
Slimes
2,822
0.00 star(s) 0 ratings
