SE-40. Protofiles
SE-40. Protofiles
Files are mostly in DXF and STL format.
Assembly can be viewed in STEP and 3D-PDF.
The prototype material is plywood, metric 3mm.
Other material, other thickness is possible,
You then may need to adapt the slots In CAD.
Njoy!
date: 30082022
After cutting proto V2 there where quite a few little mods/improvements to make.
Now into proto 2.1, cutting and checking files-parts🛠
date: 15092022
Many extra improvements and additions to the cable management made.
-SE40-
Downloads
380
1,120
0.00 star(s) 0 ratings
Latest updates
  1. SE40-Version-2.1- date 15-09-2022
    Final 2.1 prototype files here to try out. Any remarks, possible improvements please do let me know.
