THINK C development
THINK C development
I forgot to add InitWindows() in the setup phase of my barebones project contained inside the starter project folder, inside the 'THINK c dev tools' volume. This will lead to great frustration as you attempt to use Quickdraw without having a surface to draw onto!
Solution 1: redownload either of the version 2 zip files (there's a version 2 hda volume and a version 2 hfv volume, take the one you need)
Solution 2: You can fix it yourself with your older version 1 volume by typing in:
C:
InitWindows();
between the lines:
C:
InitFonts();
and
C:
InitMenus();
Contains lots of workflow related tips, they walk you through steps that are specific to the very same THINK C version from this resource article here on Tinker Different.
