Best IDE to SSD?
Here's what I've done w/ my 3400c. I've used this CF to IDE 2.5" adapter with a single 2 GB CF card. This works well, but I installed this over a year ago before I learned about @Action Retro suggestion to use these M.2 Sata SSD to 2.5' IDE adapters to with low-cost M.2 Sata drives. I believe these have higher throughput and I'm testing them in Retro computers first, with the CF solution as a fall back if the drive is not recognized. Sorry I don't know if this newer, faster solution will work in a 3400.
Reactions: KingDingus
I've been using these cheap SD to IDE adapters as seen here.
Used them in my PDQ and 1400c and had no issues. Support up to 128gb if the computer allows it, and SD cards are cheap and plentiful.
Reactions: SteveHere
After hours…. I failed to get these micro-sata to 44-pin IDE to boot with either my 3400c or my Kanga (3500). They would initialize and install MacOS 8.5 and then hang at the happy Mac icon.
