BlueSCSI v2 Wifi connection failed
billbucks
75
14
Hi
I'm trying to set up the Wifi on a Mac SE30 using a BlueSCSI v2.
I put my SSID and password in the ini file.
When I start the Mac, I tried the MacTCP but it doesn't work. Looking at the log file, I'm getting the following:
* ID: 4, Type: Network, Quirks: Apple
Wi-Fi MAC: ...
Connecting to Wi-Fi SSID "...." with WPA/WPA2 PSK
Wi-Fi connection failed: -4
Later in the logs, I have
cyw43_send_ethernet failed: -6
I checked my Wifi router and it doesn't see the BlueSCSI which it used to.
-4 is PICO_ERROR_NOT_PERMITTED - which I'm (guessing) is an issue with authentication (I'll try to add these errors to the code or the wiki (or both))
Could you re-validate your SSID/password - also note that the radio is 2.4ghz only and you wont be able to connect to a 5ghz network. Also ensure your router is using WPA/WPA2 PSK.
Reactions: reukiodo
Turned out that something was wrong as none of the Wifi worked.
I installed the latest firmware on the Pico and it worked again :)
thanks for the prompt reply
Reactions: eric
