Color Classic - Mystic Bezel
Drake
Emeritus Board Member
449
795
Experimenting with some waterslide transfer paper I was able to produce a nice looking custom bezel for my color classic II.
(This unit is using a seperately purchased LC575 board with resistor swap, I still have the original parts.)
The above waterslide paper was about $15 on Amazon, Once the Apple Garamond font was printed I used clear enamel to brush a thin layer over the print, this protects it from the water and potential bumps/scratches.
Smith & Nephew medical adhesive remover was used to remove the silkscreen from a spare Color Classic bezel with great results.
The finished product is better than I honestly expected and adds a good touch to the work I've put into this machine :)
That looking slick! Water transfer paper is awesome stuff :) It's definitely the way to go if you want it to look like it came like that from the factory.
That looks amazing!! Is there a way to 3D print this, or is this a better method?
I'm sure someone here may be able to tackle a reproduction, I could certainly match the specs in my resin printer. I just happened to have a spare bezel from a shipping explosion Color Classic :(
Color of machine plastics will vary due to age. It would be best to 3d print in a color, then prime and paint in a matching color to the machine. You'll never find a plastic that perfectly matches more than 1 machine.
Wiser words never spoken!
So, is Drake making these decals? I was told that Javier Rivera also made them. I’d like to order a couple for my Mystic.
I could mail some BUT everything I own is packed away until we get possession of our new house month end (April).
