How do I get rid of this code? I think it's stopping my portable from booting before I reset.
Froggy814
168
46
Squaw Valley, CA
Hello everyone, I done so much research on the macintosh portable I didn't think it was possible to have such a hard to find infomation machine. Alright straight to the problem.
I finally got my portable to boot with 2 files. A custom bluescsi.ini, a macpack vhd. But finally after flowing some solder on 2 chips that were caught in a lead acid battery leak, so that the IC lifted from the board I got it to boot, but not before I reset it. Do you know why? Here is what I think is the problem this line in the log.txt. Please tell me if you have an idea. DBG Waiting for USB enumeration to enter Card Reader mode. Also I would like to a photo of the 5120 with the 2 diode mods if possible. (The zener one from the hybrid module recreation from androda and thetechknights external scsi one.) If you have any other mods please tell me before I put my portable back together. Thanks! :)
I was able to fix it by being patient... Now it's fixed! I just had to wait longer. Another portable up and running! With a unknown amount of ram in the PDS card it came with!
