Mac Plus Analog Board repair help
will
I have a Macintosh Plus that I bought and restored a year ago, and it has worked beautifully since then. At the time, I fully recapped both the analog and digital boards.
Unfortunately, last week, I accidentally plugged in what turned out to be a defective cable into the SCSI port. This seems to have caused a short circuit—the cable became hot, and the screen went black. I quickly turned the unit off, but the damage was already done.
I suspect the power supply took a hit because, ever since, it has been making a clicking sound at approximately 4.2 Hz. A visual inspection didn’t reveal any damaged components. With no logic board connected, I checked the +12V, +5V, and -12V lines using an oscilloscope and observed the voltage trying to establish itself before cutting off and restarting in a loop. Checking the power lines' load resistance didn’t indicate any obvious short circuit either—though I couldn’t find the expected load values.
Has anyone experienced a similar issue? Any advice on which components I should inspect first?
Thanks, everyone!
Please make sure that there is no short circuit on the mainboard, and then check the connection wires between the mainboard and the analog board and the fuses on the connection wires.
