Macintosh Diagnostics software tools
Jimbo Slice
10
I'm trying to load some utilities onto my BMOW floppy emu to help test and diagnose problems in my 68k macs. I've read good reviews about MacEKG and I found a copy here (https://www.macintoshrepository.org/573-macekg). Is this a trusted, reliable software to use? I'm also not sure how to use .SIT files on my old macs. Any help/advice is much appreciated, thanks!
Cool. I'll give a try.
SIT are compressed files, inside you have the disk image. As I downloaded it, I uncompressed it already in case you want to get the image:
Disk 1: https://www.dropbox.com/s/n1f3o5dgnrwyfzk/MacEKG:Disk One.image?dl=0
Disk 2: https://www.dropbox.com/s/jqa8qos00vpn40m/MacEKG:Disk Two.image?dl=0
THANK YOU! May I ask your process of uncompressing it? I noticed BMOW floppy emu came with a preinstallled program called "stuffit expander" but im not sure how to use.
