SE/30 Horizontal lines due to an oversight
Elemenoh
460
449
Bay Area
I recently recapped a SE/30. After cleaning, it booted to a gray screen with cursor and nothing else if a SCSI drive was attached. It booted okay if only a floppy was connected. As a matter of troubleshooting I removed the SCSI IC, cleaned underneath and put it back. Afterwards, it was then showing horizontal lines on the screen with no chime. I was going nuts looking for what was wrong, assuming something with the RAM. After tons of hunting I found D28 was short to +5v. I replaced a diode and kept hunting along that path until finally getting back to the SCSI IC where I found a bridge from pin 23 (D28) to 24 which happened to be +5v. D'oh!
It was a hard bridge to spot, but still I should have obviously just rechecked the SCSI IC more carefully before going on a wild goose chase.
Have any of you had similar moments? How did it change how you perform repairs?
After my first handful of surface mounted chips didn't work after initial replacement, I developed the habit to brute-force check every pair of neighboring pins for those hard-to-spot bridges. When I get a continuity beep, I double-check the schematics in case the neighboring pins are actually connected via a trace. It takes time, but where I am in my repair learning (I'm still more of a novice than a proficient repairer) it has started leading to more successful repairs.
