[SOLVED] Automating sound output selection?
misterg33
69
Looking for a way to automate sound output selection. For some reason one of my SheepShaver instances is defaulting to selection = none, every time I restart it. Hoping smeone knows of a scripting addition or something similar where I can set it to output = built-in on startup. Thanks in advance!
Solved this by copying over the "sound scripting" addition from a 9.1 install. Although OS 9.1 isn't supported on sheepshaver, the scripting addition seems to work fine under OS 9.0.4.
tell application "Sound Scripting"
set sound output device to "Built-in"
end tell
Save script as app, place in startup items folder. Voila.
