Some resources for Fujitsu FM Towns II UG20
BigBadBiologist
13
26
13
I recently did a refurbishment of a Fujitsu FM Towns II UG20. These are super cool little not-quite-DOS-compatible x86 all-in-one machines. It seems like the information is disbursed all over the place on the web, so I thought I'd do a post of the most useful things I found and the resources I created.
I did streams showing disassembly and tried to point out all of the different types of screws:
Reassembly:
How to service the floppy drive, modify a 72 pin SIMM to work, and boot from BlueSCSI:
I made capacitor maps for all the boards (although I found only the CD-ROM, main power supply, and one cap on the CRT board really needed to be done):
CD-ROM
Neck Board
Main Power Supply
Second (high voltage?) power supply
CRT Control board
Motherboard
AV board
This is my a zip of my BlueSCSI image (just unzip and copy all the files to a SD card, hold A+B on controller, and boot from SCSI ID 4): https://drive.google.com/file/d/1ZB_D1jfiavTeT94jPGtFlsRp9_ehI5qI/view?usp=sharing
Useful links for FM Towns from around the web:
Software archive:
How to set up a drive emulator such as BlueSCSI:
How to mod the 72 pin SIMM for FM Towns:
/edit: I’ll work to clean up the formatting. This is a mess!
Reactions: bakkus
